Monitor website through Zabbix proxy
  • flipper999
    • Feb 2013
    I've searched and read the manual, but couldnt find if it is possible to monitor
    a website using a zabbix proxy.
    Anyone know if this is possible and if so how to do this?
    Regards,
    Flip
  • flipper999
    • Feb 2013
    Can anybody answer this?
    • heaje
      • Sep 2009
      • 325
      I imagine you can. Try setting up a proxy and see what happens.
      • flipper999
        • Feb 2013
        I tried this before posting my question.
        I don't see how to assign a webscenario to a Zabbix proxy.
        Following the manual, assigns it to a application group, but then
        the zabbix server itself executes the webscenario in stead of the proxy.
        • richlv
          • Oct 2005
          • 3112
          you must assign the host (that web scenario is created on) to be monitored by a proxy
          • flipper999
            • Feb 2013
            Ok, thanks for your reply!
            So a webscenario can not be assigned directly to a Zabbix Proxy?
            And if assigned to a host that is monitored by the proxy, is the website checked from that host or from the proxy?
            And assigning to a host, should that host be a Zabbix Agent or does this not matter?
            • heaje
              • Sep 2009
              • 325
              Web scenarios are assigned to hosts and hosts are assigned to proxies. Checks for a host are run from the proxy it is assigned to, so the same applies to web scenarios. Any web scenarios for a host will run from the proxy that the host is assigned to. I don't believe that a Zabbix Agent is required for web scenarios , but I can't say that I've tried it without one.
