I'm using Zabbix 2.0.4; I have many items whose value is calculated as a sum of items from other hosts:
This value is used to plot a graph and everything works fine if all items return a value but if for some reasons (for example if an host goes offline) an item doesn't return a value, the graph isn't plotted anymore until until the item starts collecting data again.
My question is: is there a way to make an item return a default value (let say 0) if he can't retrive data?
BW_IN:last("Server1:net.if.in[eth0,bytes]")+last("Server1:net.if.in[eth1,bytes]")+last("Server2:net.if.in[eth0,bytes]"+last("Server3:net.if.in[eth0,bytes]")
