I am trying to get the zabbix win32 service installed, it installs successfully, but when i go to start it, it tells me that it started in an untimely manner.
# This is config file for zabbix_agent
# To get more information about Zabbix,
# go http://zabbix.sourceforge.net
# IP address of Zabbix server
# Connections from other hosts will be denied
Server=192.168.1.72
Hostname=MEGATRON
LogFile=C:\zabbixagent.log
# Spend no more than Timeout seconds on processing
# Must be between 1 and 30
Timeout=3
# Format: UserParameter=<key>,<shell command>
# Note that shell command should return numeric value
#UserParameter=system[test],who|wc -l
### Set of parameter for monitoring MySQL server (v3.23.42 and later)
### Change -u<username> and add -p<password> if required
#UserParameter=mysql[ping],mysqladmin -uroot ping|grep alive|wc -l
#UserParameter=mysql[uptime],mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
#UserParameter=mysql[threads],mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
#UserParameter=mysql[questions],mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
#UserParameter=mysql[slowqueries],mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
#UserParameter=mysql[qps],mysqladmin -uroot status|cut -f9 -d":"
#UserParameter=version[mysql],mysql -V
Server=192.168.1.72
Hostname=MEGATRON
Timeout=3
