how to get ip using SQL
  • tyommik
    • Jan 2013
    Hello! I've tryed to get hosts ip by sql. For example sql query
    PHP Code:
    SELECT ip FROM hosts,interface WHERE hosts.hostid =10228;
    lists array but i want just ip of necessary host.
    Thanks!
  • neilb
    • Jan 2013
    • 33
    try instead : sql >
    select * from interface
    and join that back to the host table if required using hostid.
    N.
    • tyommik
      • Jan 2013
      Thank you for reply!
      Right answer "select ip FROM interface WHERE hostid = 10233". RTFM
      • neilb
        • Jan 2013
        • 33
        no worries. The db schema actually uses obvious names for the tables, which is quite a relief versus some other systems!
        the only weird one I've found so far is that templates are actually stored as hosts (in the hosts table).
