Running commands as Root user
  • sworded
    • Feb 2013
    I would like an Item to run commands as the root user
    Item:
    system.run[cat /var/log/messages]
    Right now, commands are being ran as the zabbix user and I get permission denied a lot. Is it possible for system.run to run as root?
  • neilb
    • Jan 2013
    • 33
    you have a choice i believe of running the agent as either zabbix or root. by default it's user zabbix, or turn on the parameter "Allowroot"
    the alternative is to add the command to /etc/sudoers and sudo accordingly either with userparameters or within a local (to the agent) shell script.
    N.
