Change Displayed Time For Web Graphs?
  • sirtech
    • Aug 2012
    • 25
    We have a host that is monitored using the web monitoring scenarios section i Zabbix which works well. Unfortunately, the host seems to be problematic and is failing "about" once a week.
    I can't find how to change the timeline on the graph that is displayed in the web monitoring section to be able to see more than 1 hour to be able to confirm this though. The manual doesn't mention how to do it (https://www.zabbix.com/documentation...monitoring/web). It seems like it should be simple though, like it is in every other graph in Zabbix.
    Can anyone shed some light on this?
  • heaje
    • Sep 2009
    • 325
    Unfortunately I don't have any web monitoring to verify this, but there is usually a thin bar that says "Filter" on it just above the graphs. Usually, it's very noticeable because it has the timeline bar you're looking for, but if it gets closed, it can be really easy to miss.
    • sirtech
      • Aug 2012
      • 25
      You're right, I didn't see it because it was closed; the layout is exactly as it is in all the other graph panels in Zabbix. I'm so used to it being open. Love these easy solutions, even if it does make me look stupid, so thanks
