Problem with template installation
  • sanjose
    • Mar 2013
    I am new to zabbix monitoring system. I was unable to install new template. Templates are from hire https://github.com/jjmartres/Zabbix/...x-cisco-envmon, ZBX-CISCO-ENVMON this template. As was stated in Install guide, I have edited zabbix_server.conf configuration file and add following line:
    ExternalScripts=/etc/zabbix/externalscripts
    Then in /etc/zabbix/externalscripts directory I place echo.something script with appropriate permissions. And It is working.
    I was unable to determine how I should do following step “Add a value mapping named ciscoEnvMonState with the following values:” ? Where should I implement this mapping values?
    When I import template into system without changing value mappings it is displaying following error: XML file contains fatal error 41:Specification mandate value for attribute data-pjax-transient [ Line: 37 | Column: 33 ]
  • jjmartres
    • May 2012
    • 18
    To create Value Mapping you can follow the Zabbix manual : https://www.zabbix.com/documentation.../items/mapping
    Which version did you use ?
    • sanjose
      • Mar 2013
      Thank you for helping. My version was 2.0.1. I have successfully installed templates.
