Filter on interface SNMP discovery rule
  • SupportGuy
    • Mar 2012
    • 30
    Sorry if this point has already been answered, up to now I've not found the response to my question.
    I have to monitor the network trafic of a particular interface for an existing park of servers. Each server has dozen of interfaces.
    The interface I want to monitor is not the same on whole servers. the only common point is the naming rule.
    I would like to know if it is possible to make filtering on the SNMP value in he discovery rule to retrieve only the item of a particular interface at the discovery rule level better thant in the item prototype level with something like, for the SNMP OID :
    IF-MIB::ifAlias["MyIfAlias"]
  • SupportGuy
    • Mar 2012
    • 30
    Sorry for eventual disturbance, I've finally found the solution.
    Using the "Filter" fields of the discovery rule, "Macro" and "Regexp".
    In Macro I use {#SNMPVALUE} and in regexp, for example to only take in account interfaces which name is "MyInterfaceName", the string hereafter:
    [^- .]MyInterfaceName$
    • harmonica
      • Jan 2009
      • 251
      In my case i do not want to collect information for "Virtual-Access<ID>" interfaces on several routers we have. Whats the right regular expression to exclude this interfaces?
      • harmonica
        • Jan 2009
        • 251
        Anyone can give a tip with this issue?
        Regards
        • harmonica
          • Jan 2009
          • 251
          The solution is simple. I use expression ^Virtual to exclude Virtual-Access interfaces.
          Regards
          • troffasky
            • Jul 2008
            • 639
            ...which would then match *any* interface beginning with "Virtual".
            To match Virtual-Access0 - Virtual-Access9:
            ^Virtual-Access\d{1}$
            To match Virtual-Access0 - Virtual-Access99:
            ^Virtual-Access\d{1,2}$
            etc
