Hi!
I would like to monitor Oracle locks with ZABBIX + DBFORBIX.
My current setup is working properly and is already receiving data, when there is a lock, Latest data shows something like this when there ARE locks:
155 Holder: TX Exclusive No Lock 10084 262163 3156449 SCHEMA.OBJECT
when there ARE NO objects locked, then:
none
none
none
none
new line is added with approx 1 minute interval here.
Trigger looks like this:
{HOST.SID
BforBIX.Oracle.locks.str(none)}=0
Which will change status of trigger as soon as the data received by item is something else than text "none".
It works, BUT fires up way too often because it is a legit operation to lock objects for time of writing data in Oracle DB tables, but if a lock stays for more than 30 minutes, then it is when one should start looking at it.
What do you suggest for this?
none
none
none
none
{HOST.SID
BforBIX.Oracle.locks.str(none)}=0Which will change status of trigger as soon as the data received by item is something else than text "none".
