Zabbix web problem
  • Shmiti
    • Feb 2013
    Zabbix web problem
    I have run into the following scenario:
    I have 2 tabs:
    1 is constantly in the triggers section
    2 is in the graphes
    when I choose a specific graph of a specific host, after refresh of the triggers tab, it only shows the triggers for the same host, which, obviously is a side affect that is not wanted.
    is there any way to avoid it? like using the queries (host, item etc) via URL and no session?
    thanks
  • Shmiti
    • Feb 2013
    bump
    help anyone?
    • heaje
      • Sep 2009
      • 325
      Probably the only way to avoid the issue is to have the two pages in two separate browsers. That way the session is different for each window and you shouldn't run into this problem.
      • heaje
        • Sep 2009
        • 325
        Another thing that may work (I haven't tried it) is to disable the checkbox called "remember selected" in "Adminstration"->"General" in the "GUI" combo box option . That is a global setting though and may be a hinderance in other locations.
