What's The Typical Approach to Monitor Different Instances of One Host?
  • zjerryj
    • Mar 2013
    • 16
    For instance, I have several MySQL instances running on the same host. And I have a template for monitoring MySQL server.
    There're two options I can think of:
    1. Use discovery rule in template, and write a custom script to provide the JSON.
    2. Build different hosts from the same template, and use host macros to customize the port.
    Which one is preferable?
    A bigger question, should there be only one zabbix host per real server?
    In Cacti, we tend to use template-host approach, i.e. every template has a corresponding host, even they are from the same server.
    How's the "zabbix way"?
    Thanks.
  • heaje
    • Sep 2009
    • 325
    Both are the "Zabbix way". The approach you take is really all about preference.
    • zjerryj
      • Mar 2013
      • 16
      Actually I'm hoping there would be an example for setting up large-scaled monitoring system. How to arrange the host groups and hosts, and templates, the various services (instances).
      Zabbix does not have a tree view mode, so the only option is to represent hierarchy with more than two levels in host groups' and hosts' names, right?
