Hi everybody,
I've spent a lot of time trying to configure triggers and actions, without managing to associate a trigger based on a template with a action.
A exemple to be more understandable :
- I created a template, called LINUX_HOSTS
- this template has an item, whatever you want, i.e. proc.num[bash] to count the number of bash launched on the server
- about 10 servers are monitored using this template, everything works
- a trigger is defined : {LINUX_HOSTS
roc.num[bash].last(0)}>1, whose name is "too many bash"
- this trigger is automatically applied to the servers (very good job
- I can notice a good working for these triggers
- then I decided to plan an action, based on a trigger : "trigger = too many bash", this action would send an email.
- when a trigger is becoming ON or OFF, the change of state can be seen in "events" but no action is happening.
To confirm this problem, I tried to make the same without template, only one server : it works
Has someone already met this problem ?
Is there any solution ?
Could I use any other possibility to build my actions ?
Thank you in advance !
ENDORPHIN
roc.num[bash].last(0)}>1, whose name is "too many bash"- this trigger is automatically applied to the servers (very good job
)- I can notice a good working for these triggers
ENDORPHIN
