Comparing items with other items or previous values
  • crlf
    • Mar 2013
    • 13
    I'm trying to implement a trigger when a value suddenly drops or rises (think free space or ambient temperature). I'm thinking about comparing the last value with a value from the previous day, but I don't know how to accomplish this.
    Theoretically, it should be "prev_free_space - current_free_space > some_value", but trigger expressions don't seem to support such a thing. Do they?
    Is there any other way to do this using some feature that I don't know about? I'm using Zabbix 2.0.5.
    Thanks.
  • eskytthe
    • May 2011
    • 363
    You could e.g. use the avg function, with the time_shift parameter
    BR
    Erik
    • crlf
      • Mar 2013
      • 13
      But can I do "average_some_time_ago > current_value - some_threshold"?
      From the docs it doesn't seem to be possible to compare two items with each other in the same trigger...
      • eskytthe
        • May 2011
        • 363
        Yes as far as I know - Take a look at example 11 (and operators in the start of the page):
        Br
        Erik
        • crlf
          • Mar 2013
          • 13
          Thanks, that worked.
          I ended up with this rule:
          {server:vfs.fs.size[E:,free].last(0,1d)}-{server:vfs.fs.size[E:,free].last(0)}>10G
          • lustigerpinguin
            • Jun 2013
            • 14
            Permanent warning
            I used a similar syntax for a trigger.
            (my test: {zabbix-test.dev.nsynd.com:vfs.fs.size[/boot,pfree].avg(1200,300)}-{zabbix-test.dev.nsynd.com:vfs.fs.size[/boot,pfree].avg(300)}>3)
            The problem: after a short time: the problem isn't available! What can I do for a permanent warning on the main page (Dashboard)?
            Regards
            lustigerpinguin
