Zabbix:alerte
  • marwaIF
    • Mar 2013
    Zabbix:alerte
    Hello everyone,
    someone can explain to me the alert system in Zabbix and especially the table action, please
  • heaje
    • Sep 2009
    • 325
    That's an incredibly broad question. What specifically do you want to know? The basics of it are this:
    1. Data is pulled into Zabbix with items
    2. Triggers can be created to look at item data and report on some sort of threshold. An example is to have a trigger go off if Zabbix finds a server's CPU idle time to be less than 20% for the last 5 checks.
    3. When a trigger goes off, it generates an event (https://www.zabbix.com/documentation.../config/events).
    4. Actions are based on events. Whenever events occur that match the conditions listed in an action, the action does whatever you tell it to (send an email, run a script, etc.). For more information, look here. Make sure you look over the "Media types" and "Actions" sections on that page.
