Command with zabbix 1.1 for service,processor and Process
  • smad
    • Mar 2005
    • 27
    I looked around on the forum and can't find the answer.
    I installed zabbix 1.0 and I used command like :
    service_state[ServiceName]
    proc_cnt[NameProcess]
    cpu_util[processorNumber]
    But it's seems that with the new version, the command have changed:
    I found for the CPU : system.cpu.load[,avg1]
    But on this one I can't make it work for a server with several Proc.
    I tried : system.cpu.load[1,avg1], but It doesn't work.
    So, what's the command to check the Service State on a windows server, and how can I check several proc?
    Thanks for your help.
    Damien
  • erisan500
    • Aug 2005
    • 285
    I think you should be using system.cpu.util[1,,avg1]
    Greetings
    EriSan
    • smad
      • Mar 2005
      • 27
      Not Supported
      ummmh
      doesn't seems to work: [Not Supported]
      Can I check a log some where to see where the problem ?
      details:
      Description: Processor$1 load1
      Type: ZABBIX agent
      Key : system.cpu.load[<cpu Num>,,avg1]
      Type of information: Numeric (float)
      Units:
      Use multiplier Do not use
      Update interval (in sec): 5
      Keep history (in days): 7
      Keep trends (in days): 365
      And what about the service, is it the good command ? service_state[ServiceName]
      Thanks for your quick reply.
      • erisan500
        • Aug 2005
        • 285
        Did you also installed the new agent on the windows pc ?
        EriSan
        • smad
          • Mar 2005
          • 27
          yep
          Yes, indeed.
          • KitWalker
            • Jan 2006
            • 17
            Hi, for the several processors I use:
            system.cpu.util[0]
            system.cpu.util[1]
            system.cpu.util[2]
            system.cpu.util[3]
            For the Services, the Key remains unchanged:
            service_state[ClusSvc]
            • smad
              • Mar 2005
              • 27
              It works.
              • smad
                • Mar 2005
                • 27
                still some problem
                Hello everybody :-)
                I still have some problem with the Service. :-(
                The host send back the information about the srevice but always on 1
                And I can stopped a service but it's still on 1 for zabbix.
                what's wrong ?
                how can I check on my host if it's taking the good information ?
                Damien
                • smad
                  • Mar 2005
                  • 27
                  my mistyake
                  Sorry, My mistake.
                  I didn't used it properly.
                  I used the Display Name instead of the Service Name:
                  service_state[IIS Admin] instead of the correct service_state[IISADMIN]
                  D.
