Error: OID not increasing
  • hmcs
    • Mar 2013
    • 14
    I'm trying to montior a teldat bintec router using "Template SNMP Interfaces" via SNMP2. I'm getting an error "OID not increasing" from teh discovery rule. Using snmpwalk I get following output:
    snmpwalk -v 2c -c public 192.168.1.1 IF-MIB::ifInOctets
    IF-MIB::ifInOctets.0 = Counter32: 0
    IF-MIB::ifInOctets.1 = Counter32: 0
    IF-MIB::ifInOctets.2 = Counter32: 0
    IF-MIB::ifInOctets.1000000 = Counter32: 782955907
    IF-MIB::ifInOctets.1000001 = Counter32: 0
    IF-MIB::ifInOctets.1050000 = Counter32: 1228974579
    IF-MIB::ifInOctets.1050001 = Counter32: 0
    IF-MIB::ifInOctets.1010000 = Counter32: 270750
    Error: OID not increasing: IF-MIB::ifInOctets.1050001
    >= IF-MIB::ifInOctets.1010000
    With the -Cc option ("do not check returned OIDs are increasing") of snmpwalk it works fine.
    Is there an option in ZABBIX to disable this check or to get it work?
    Regards
    Henry
  • szenrobi
    • Jan 2011
    • 13
    I made a similar question about a month ago, but still no real answer, just thry to make an trouble ticket.
    There are OID-s with deacreasing numbering. They are also impossible to monitor with zabbix.
    I am waiting for answer too.
    Robert
    • hmcs
      • Mar 2013
      • 14
      SNMP Error: OID not increasing
      Well,
      strange is, that on some bintec models it works fine....
      • hmcs
        • Mar 2013
        • 14
        got help from Teldat-Support: you've to set "snmpAdminGetOrder=sorted" in the MIB of the device and it works all fine
        bye
        Henry
        • Mojarrison
          • Apr 2013
          Hi people,
          First of all, sorry for my poor english level
          I've get a similar error with the OIDs in SNMP device template. I resolve it (don't remember how), but one hour later, all the monitorized servers throw alerts "Server X was unreachable", "Server Y is down". In all cases the servers were OK, but Zabbix Server see them like "down status".
          All of them turns between ON and OFF status, too with the server unmonitorized... so I'm trying to re-install all the stuff O_O
          Can anyone help me, please?
          • aquarios
            • May 2021
            You can force the "-Cc" option of the SNMPwalk to be applied globally (for all user) - including Zabbix the following way:
            printf "dontCheckOrdering 1\n" | sudo tee /etc/snmp/snmpwalk.conf
            Also check the "Max repetition count" setting on the host's interface level to prevent the output from being truncated
