Zabbix on RHEL 6.4 from RPM, Install broken?
  • T-One
    • Jan 2011
    • 12
    i tried to install zabbix 2.0 from the official zabbix yum repo and also from epel, both with the same error:
    yum install zabbix-server-mysql zabbix-web-mysql
    stops with:
    --> Processing Dependency: php-bcmath for package: zabbix-web-2.0.5-1.el6.noarch
    --> Finished Dependency Resolution
    Error: Package: zabbix-web-2.0.5-1.el6.noarch (zabbix)
               Requires: php-mbstring
               Requires: php-bcmath
    php-bcmath and php-mbstring are not available via standard redhat repos and also not via EPEL. i got the exact same problem if i try to install it via the EPEL zabbix packages.
    so from my point of view, its not possible to install zabbix on a standard machine at all.
  • T-One
    • Jan 2011
    • 12
    Already solved by myself.
    php-mbstring and php-bcmath are gone from the main software channel in RHEL 6 and are now available via the "RHEL Server Optional (v. 6 $arch)" repo.
    if someone cant find this packages, just activate the mentioned software-channel in your RHN.
    An update of the documentation with that info would be nice.
