system.cpu.util (ZabbixW32)
  • Tubbysdad
    • Oct 2004
    Hi everybody.
    I am a long term Zabbix 1.0 user (2 years or so) and have recently installed Zabbix 1.1. However, I cannot get a reliable value from the above item check.
    I am running the new agent, with active checks on a Windows 2003 server. I seem only to get a value for system.cpu.util every 15 minutes or so. I have tried all sorts of things to get it working.
    What I would like to know is how exactly should I use syste.cpu.util? I have tried system.cpu.util[], system.cpu.util[all,,], system.cpu.util[all] but none seem to work reliably.
    All other active checks work fine.
    On another Windows 2000 server I am monitoring I can't even get a value returned for system.cpu.util, even though it uses the same template as the 2003 server.
    Does anyone have any suggestions.
  • cameronsto
    • Oct 2005
    • 148
    No suggestions for you, just wanted to report I'm having the same issue on Windows XP. The items are listed as unsupported.
    -cameron
    • Tubbysdad
      • Oct 2004
      CAn anyone help?
      Sorry to post again but surely someone must know what the correct syntax for this command is? I can't get this item to work on my Windows machines and other Active checks aren't working on my Solaris servers.
      I presume Active Checks have been fully tested so I must be doing something wrong. I would appreciate any help with Active Checks in general and the system.cpu.util command specifically.
      Thank you.
      • eaglei15
        • Jun 2006
        • 12
        CPU util
        system.cpu.util[,,avg1]
        this works for me fine ...
        • mrbig
          • Aug 2006
          Solution
          I had the same issue, until I figured out: I have to set the type of information to float. Then all the above examples will work fine.
