Hi All,
Hope you can help.
I have created a powershell script which retrieves the Microsoft SQL Instances that are installed on the machine and also the dabases within them.
They are stored as 2 Variables and the response and is output with the required JSON format.
The 2 variables are #MSSQLINSTANCE and #MSSQLDBNAME
Everything seems to work well and I can use a single variable in my item prototypes, however when I try and use 2 variables it doesnt work.
For instance...
If I create a perfmon counter
perf_counter["\MSSQL${#MSSQLINSTANCE}
atabases(_Total)\Log File(s) Size (KB)"]
It works ok, I get the Databases(_Total) monitored for each of my instances.
Likewise if I set it up as
perf_counter["\MSSQL$INST1Databases({#MSSQLDBNAME})\Log File(s) Size (KB)"]
I get the individual database log file size monitored for instance INST1
So I know both variables work.. however when I try and combine the two:
It doesnt work ? I want it to monitor the databases returned in MSSQLDBNAME if they exist on instance MSSQLINSTANCE
Can anyone help?
Kind Regards,
Craig
Hope you can help.
For instance...
atabases(_Total)\Log File(s) Size (KB)"]It works ok, I get the Databases(_Total) monitored for each of my instances.
atabases({#MSSQLDBNAME})\Log File(s) Size (KB)"]It doesnt work ? I want it to monitor the databases returned in MSSQLDBNAME if they exist on instance MSSQLINSTANCE
Can anyone help?
Kind Regards,
Craig
