Variable in Userparameter
  • marc
    • Oct 2004
    • 146
    Hello all,
    i have defined the following userparameter:
    UserParameter=cmta.sendmailup[*],/etc/init.d/sendmail status up
    "/etc/init.d/sendmail" is a customized script and waits for an id like.. BB-Out
    Example:
    lp0056:/home/qx56451 # /etc/init.d/sendmail status up BB-out
    1
    i defined the following item and key..
    BB-Out (as desc) and key cmta.sendmailup[BB-out]
    within the log i see:
    006495:20060612:153000 Got line:cmta.sendmailup[BB-out]
    006495:20060612:153000 Sending back:Status of sendmail daemons:
    this means it doesnt use the keys [variable] at the cli without an argument i get this..
    I want to monitor a lot of diffenernt sendmail instances and need to use a variable because it would be senceless to add a line foreach instance. They are different on each host and may change within a day. I dont want to give shell access to the gui admin to solve this issue in zabbix_agentd.conf.
    What am i doing wrong?
    regards,
    Marc
  • marc
    • Oct 2004
    • 146
    ok i forgot the $1 in the scripts execution path
