Web monitoring in Maps
  • simonquentel
    • Mar 2013
    • 49
    I tried to add web monitoring in maps, but it seems that the option doesn't exist.
    I tried to find a way to link a web status to a trigger but couldn't do it either.
    That is a real limitation since I use a mix of technical controls on servers / DBs etc (through triggers) and also web scenarios to assess my applications availability and cannot have them all information gathered on the same map.
    Is there an add-on or work-around?
    Is it something scheduled in the roadmap?
    Thnak you in advance!
  • simonquentel
    • Mar 2013
    • 49
    I checked if I could use a screen to gather web monitoring and a map but there is no option to add a web monitoring table in a screen either right?
    Is it something available in version 2.2?Next?
    Thnks in advance for your replies!
    • simonquentel
      • Mar 2013
      • 49
      I am also thinking of creating items with ODBC to get the web monitoring status in zabbix db and retrieve the info in a trigger, but would be quite a hard way to solve my issue.
      Any other idea?
