Minum function usage
  • anjiytwok
    • Dec 2012
    • 44
    I have one case like this.
    Where I am pulling the data from host CPU Utilization percentage.
    so, when the service up and running I am getting the correct usage of CPU.
    but when service is down my CPU utilization percentage is going to negative values. To avoid this I would like to add like this, but it's NOT working for me.
    can you guide me the correct syntax.
    which is minum it should refect that one:
    selected the Calculated Item and in the that box I have used like this.
    min(0.00001,item1Data)
    please correct me.
  • Heilig
    • Mar 2013
    • 366
    Is the main problem that the item system.cpu.util become unsupported?
    If so, plese read this issue:
    ZBX-5201
    and update Zabbix agent to 2.0.5.
