[API] Get Web monitoring metrics
  • Matthieu
    • Mar 2011
    • 41
    I try to get data from a web monitoring host like response time or speed. But when I try to perform a "get item" with the id of my host, I didn't see theses items.
    Maybe I've not use the good way.
    Matthieu
  • neogan
    • Sep 2011
    • 118
    Matthieu
    Do you read follow links? I hope it will help you.
    webcheck.get and Scenario step
    • Matthieu
      • Mar 2011
      • 41
      Yes, I've already see these links. But the get command retrieve only the configuration of a web monitoring scenario, not the latest values.
      • Heilig
        • Mar 2013
        • 366
        Try history.get method.
        • Matthieu
          • Mar 2011
          • 41
          Humm good idea, thanks Heiling. I'll try to retrieve my data with this solution.
