rsync of repo.zabbix.com
  • GeneBean
    • Jan 2012
    • 21
    Does anyone know if there is a way to get rsync access to the official repositories located at repo.zabbix.com?
  • James5mith
    • Sep 2013
    I just joined the forums to search for this very question.
    My current desire is to have a local mirror of zabbix that I then use to deploy to all of my machines locally. This saves bandwidth on the zabbix servers, and allows me to tighten up my network.
    With CentOS/puppet/etc. I can rsync the repo to a local mirror server, and update from that, thus only having one hole in my firewall rather than 100's.
    Any advice?
    • LenR
      • Sep 2009
      • 1011
      I think you can use wget, something like this for each repo area
      cd /var/www/html/pub/zabbixzone/6Server/x86_64/
      wget -q -r -t1 --no-parent -nd --mirror http://repo.zabbixzone.com/centos/6Server/x86_64/
      createrepo --update /var/www/html/pub/zabbixzone/6Server/x86_64/
      • James5mith
        • Sep 2013
        Why would I use zabbixzone and not the main repo.zabbix.com ?
        • LenR
          • Sep 2009
          • 1011
          That was just an example of the technique, I didn't check the URL
          • James5mith
            • Sep 2013
            Fair enough.
            I went ahead and gave it a try. Seems to work. Don't know if they will appreciate a nightly crawl through the server with wget, but I still think it's better than 100's of servers hitting it each time we try and update.
            • cru5ader
              • Mar 2012
              • 72
              looks like someone else need rsync:
              looks like someone else need rsync: https://support.zabbix.com/browse/ZBXI-3
              • rcsheets
                • Jul 2016
                This is now being tracked as ZBXNEXT-3050, though it doesn't seem like it's getting any attention.
                • rcsheets
                  • Jul 2016
                  Hooray!
                  Looks like rsync access has finally been enabled!
                  The feature request has been closed and rsync access appears to be working.
                  rcsheets@stinger:~$ rsync repo.zabbix.com::
                  mirror
                  rcsheets@stinger:~$ rsync repo.zabbix.com::mirror
                  drwxr-x---          4,096 2016/08/16 06:25:25 .
                  lrwxrwxrwx             27 2016/08/16 06:25:25 RPM-GPG-KEY-ZABBIX
                  -rw-r-x---          1,333 2016/08/16 03:46:03 RPM-GPG-KEY-ZABBIX-79EA5ED4
                  -rw-r-x---          1,719 2016/08/16 03:46:04 RPM-GPG-KEY-ZABBIX-A14FE591
                  -rw-r-x---          2,938 2016/08/12 22:23:06 zabbix-official-repo.key
                  drwxr-x---          4,096 2012/01/23 07:37:31 non-supported
                  drwxr-x---          4,096 2016/08/11 09:45:13 zabbix
                  The total size is currently just under 10 GiB.
                  • kloczek
                    • Jun 2006
                    • 1771
                    To create mirror of any yum repos all what you need is to install yum-utils package.
                    In this package you can find reposync program
                    # reposync --help
                    Yum-utils package has been deprecated, use dnf instead.
                    See 'man yum2dnf' for more information.
                    Usage:
                      Reposync is used to synchronize a remote yum repository to a local
                      directory using yum to retrieve the packages.
                      /bin/reposync [options]
                    Options:
                      -h, --help show this help message and exit
                      -c CONFIG, --config=CONFIG
                      config file to use (defaults to /etc/yum.conf)
                      -a ARCH, --arch=ARCH act as if running the specified arch (default: current
                      arch, note: does not override $releasever. x86_64 is a
                      superset for i*86.)
                      --source operate on source packages
                      -r REPOID, --repoid=REPOID
                      specify repo ids to query, can be specified multiple
                      times (default is all enabled)
                      -e CACHEDIR, --cachedir=CACHEDIR
                      directory in which to store metadata
                      -t, --tempcache Use a temp dir for storing/accessing yum-cache
                      -d, --delete delete local packages no longer present in repository
                      -p DESTDIR, --download_path=DESTDIR
                      Path to download packages to: defaults to current dir
                      --norepopath Don't add the reponame to the download path. Can only
                      be used when syncing a single repository (default is
                      to add the reponame)
                      -g, --gpgcheck Remove packages that fail GPG signature checking after
                      downloading
                      -u, --urls Just list urls of what would be downloaded, don't
                      download
                      -n, --newest-only Download only newest packages per-repo
                      -q, --quiet Output as little as possible
                      -l, --plugins enable yum plugin support
                      -m, --downloadcomps also download comps.xml
                      --download-metadata download all the non-default metadata
                    In other words .. access to the repo over rsync is not needed.
                    • rcsheets
                      • Jul 2016
                      That's great if all you need is the yum repo. If you need to mirror the entire repository, or if you simply wish to manage your mirror using rsync (which you are already using extensively if you have other local software mirrors), then rsync access is essential.
                      I for one will benefit substantially from the new rsync access. Those with different needs will be best served by different solutions. There's no call for categorically stating that rsync access is not needed.
                      • kloczek
                        • Jun 2006
                        • 1771
                        If on base URL there are multiple repos all what you need is run this command few times.
                        Additionally this command copies less because it regenerates repo index after update copy. It uses remote repo indexes to figure out what needs to be copied. It checks signs of the new packages as well.
                        Additionally on doing mirror you can make decision about delete older packages or not which may be not available on doing next mirroring cycles (on source repo side) and which may be needed on doing rollback using your mirror.
                        You can make decision about copying src.rpm packages as well (if those packages are stored in repo tree and registered in repo indexes).
                        In other words this command does not only what rsync is able to do and it doing it over the port over which repo is normally accessible so none of the other services needs to be opened on source repo side.
                        Less software running on server side -> lower risk of penetration of the repo server.
                        • dekapri
                          dekapri commented
                          Does reposync let you download other $releasever repo--e.g. rhel/8 while I run rhel/7? Or another OS repo--SLES when I run RHEL?
                      • RcaB5ayazp7RzFt33LNJ
                        • Apr 2018
                        Looks like rsync is disabled again, I can't find anything on their JIRA about this. Can anybody find it noted somewhere?
