I would like to know if there is a way to have this kind of setup, using Zabbix 1.1 final release :
- Have actions defined for 'Trigger-X' that will send e-mails when the trigger goes 'ON';
- Have, at the same time, actions defined for 'Trigger-Y' that will send e-mails when the trigger goes 'ON' or 'OFF'.
I don't see how I could get this kind of result... I would need to use conditional operators for the actions (for example, "send an e-mail when trigger name == Trigger-X and trigger value == ON").
Is there any way to do this? Anyone has a tip for me?
Thanks!
Thanks!
