Define custom trigger status
  • cbichis
    • Apr 2013
    • 30
    I would like to define some custom trigger statuses (not OK or PROBLEM), as INFO (for actions where is not needed to send recovery message):
    Of course, I can simply use on actions a diff default subject:
    {TRIGGER.STATUS}: {TRIGGER.NAME}
    to replace with
    INFO: {TRIGGER.NAME}
    However, I find more "appropriate" to just define a new TRIGGER.STATUS.
    Just that I don't seems to find in docs how to define a new status...
  • Heilig
    • Mar 2013
    • 366
    Trigger has only two status (Ok or Problem) and you can not add new (for example Info).
    So, I think that you have to use the specified method (define a new TRIGGER.STATUS in subject).
