Standard templates
  • getUP
    • Jun 2006
    • 34
    Standard templates
    Is there a way to create custom templates which include default items, triggers and actions?
    And what would be the best way to check if SSH is up on another port?
    Thanks!
  • epifanova
    • May 2006
    • 26
    1. may be change database direct
    2. some thing like net.tcp.port[<ip>, port] or net.tcp.service[service <,ip> <,port>]
    • getUP
      • Jun 2006
      • 34
      The last part confuses me.
      Would that end up like as it seems to be failing.
      net.tcp.service[ssh, {HOSTNAME}, 23123]
      I only want to specify the service and port, else having templates is rather useless because you'd end up with all servers monitoring a specified host instead of their own.
      Is there a way to have default triggers for all hosts within a template group? It seems that it is, though once again I'm running into having to specify a certain host.
      Adding {{HOSTNAME}:system.cpu.load[,avg1].last(0)}>5 fails. Is there another way? Else it's rather ineffecient.
      • epifanova
        • May 2006
        • 26
        if you want to create the template use net.tcp.service[service,,port]
        by default ip is 127.0.0.1
        • getUP
          • Jun 2006
          • 34
          From what perspective should I look at those templates? From the agent, 127.0.0.1 being the target host or the other way round?
          The reason I'm asking this is because the result always seems to be 0, which is incorrect.
          Thanks for your help so far
