Data dictionary for Zabbix db
  • cyber_geek5
    • Apr 2013
    • 19
    Is there a data dictionary available on the various tables that zabbix creates , Is there a way to find out which item is stored in which table
    For instance : If i need to know the CPU utilization which table do i query
    I need this to be able to tell my reporting software to go look at these tables / items for the required data i want
  • Heilig
    • Mar 2013
    • 366
    Please, read this and this page, maybe this urls will be useful for you.
    Also, you can enable debug mode for your user and in "Monitoring -> Latest value -> some item graph/history ->Values" verify in which table it consist.
    • cyber_geek5
      • Apr 2013
      • 19
      Hi Heilig
      Thanks for the info ,.. very informative..
      I am exploring those further
