Show switch port alias on graphs
  • nathanzachary
    • May 2013
    Hello all,
    If we have a discovery rule that finds all the ports on some Cisco 5000 series switches (and connected FEX units), the ports are shown by their respective port name (e.g. Ethernet 107/1/32) in the drop-down menus and on graphs. Is it possible to have both that port name and the port alias shown in the drop-down menus and/or the graphs?
    For instance, let's say port Ethernet 107/1/32 has an alias (description entered on the switch) of server52, is there a way to have the traffic graph for that port show:
    Traffic for Ethernet 107/1/32 - server52
    Instead of just:
    I understand that the following key/SNMP MIB will pull the port name (Ethernet 107/1/32, e.g.):
    ifDescr[{#SNMPVALUE}]
    IF-MIB::ifDescr.{#SNMPINDEX}
    and that the following key/SNMP MIB will pull the description entered for each port:
    ifAlias[{#SNMPVALUE}]
    IF-MIB::ifAlias.{#SNMPINDEX}
    So I would think that the two could be combined. I have tried making a new discovery graph prototype with a name of:
    Traffic on interface {#SNMPVALUE} - ifAlias[{#SNMPVALUE}]
    but that did not work as intended.
    Any suggestions would be greatly appreciated.
    Thank you.
  • harmonica
    • Jan 2009
    • 251
    On the discovery rule if you change Key from ifDescr to ifAlias and SNMP OID from IF-MIB::ifDescr to IF-MIB::ifAlias you will get something like:
    Traffic for server52
    • zbxgo
      • May 2013
      I think he is wanting both to display. I'm also interested in this so I don't have to maintain a list of interfaces to know which one to look at.
      • harmonica
        • Jan 2009
        • 251
        Yes the intention is to keep both and I'm also interested in this. In my example it only show Alias.
        Regards
        • nathanzachary
          • May 2013
          So it seems like the problem is actually displaying both values, not in just displaying the ifAlias instead of the ifDesc. If this isn't yet possible, would it warrant a feature request in the Zabbix JIRA?
          • abjornson
            • Oct 2013
            • 34
            Did anyone ever figure this out?
            I assumed just as you did that making the name of the discovery rule for the graph:
            Interface32 Simple Bandwidth ({#SNMPVALUE}) - (If.32.ifAlias.["{#SNMPINDEX}"])
            This almost works, but what I get in the graph names is:
            Interface32 Simple Bandwidth (Port:1 Gigabit - Level) - (If.32.ifAlias.["1"])
            So it's not replacing the token If.32.ifAlias.["{#SNMPINDEX}"] as it should....
