Good afternoon,
I'm from the Brazilian
I'm having trouble monitor directories logs generated daily by SARG on CENTOS, since I can not simply monitor whether there was an increase in the path of a directory as output the SARG because besides the name is defined based on the date, also runs a daily script to remove the folders logs older.
Because every time a new folder is SARG generated index.html undergoes change, I'm checking the checksum of the file and I need that when there is no change this checksum within one day (indicating no file generation SARG diary ), the trigger into action. Need help to mount the trigger expression used in this or a way to monitor when NO generation from a directory in a specific path within one day.
Then it will be necessary for the folder that is generated SARG 1X 1X per week and per month.
I am totally novice when it comes to Zabbix, although we monitored servers for it here, so I ask kindly that the answer is very detailed.
Thank you in advance everyone's attention.
