SNMPBuilder
  • Alan
    • Aug 2010
    • 12
    SNMPBuilder
    I'm trying to install SNMPBuilder on a Centos 6 box with Zabbix 2.6, and got thye following error message when running the installation script
    patching file jsLoader.php
    Hunk #1 FAILED at 47.
    1 out of 1 hunk FAILED -- saving rejects to file jsLoader.php.rej
    I'm at lost as what to do to solve my problem. Any help ?
  • bagni
    • Mar 2012
    • 164
    I think that is a version problem.
    Look the Zabbix Wiki:
    SNMPbuilder can be compatible with Versions: 1.8.1, 1.8.2, 1.8.3, 1.8.4RC1. Note: Additionnal patches listed below are required to achieve compatibility with 1.8.2-3 and 1.8.4RC1. It is hoped that someone will spend an hour to merge all patches and update the github code repository.
    All patches for Version 2.0.2 are merged on http://github.com/atimonin/snmpbuilder (see README)
    • Alan
      • Aug 2010
      • 12
      Thanks for the info.
      The only problems is that I've followed, and used, the instructions found in the link. with no result
      • bagni
        • Mar 2012
        • 164
        Time ago I've tried to install the SNMPBuilder, but without success.
        At last I've found more confortable and faster use the command line interface with net-snmp tools (snmp_get, snmp_walk, etc.) and build my own snmp templates.
        Bye, Lorenzo
