API: hostgroup.get with filter
  • hm75
    • May 2013
    Hello
    i use zabbix 2.0.6 and want to automate the configuration of the monitored hosts. Therefore i tried to use the api to get a list of all hostgroups from a given host. The Problem ist, whateveer i use as filter, i alway get a list of all hostgroups as respond. The json request i used is
    "jsonrpc":"2.0",
    "method":"hostgroup.getobjects",
    "params":{
    	"output":"extend",
    	"filter":{
    		"nodeids":["10111"]
    	"auth":"dbc1b01280447cf95b886986ca2b1bc4",
    	"id":"13693129326839"
    Any suggestions what is wrong?
  • Heilig
    • Mar 2013
    • 366
    Try this code:
    "jsonrpc":"2.0",
    "method":[B]"hostgroup.get"[/B],
    "params":{
    	"output":"extend",
    	[B]"hostids":"10111"[/B]
    • Heilig
      • Mar 2013
      • 366
      OR
      {"jsonrpc":"2.0",
      "method":"host.get",
      "params":{"filter":{"host":"Zabbix server"},"selectGroups":"extend"},"auth":...}
      • hm75
        • May 2013
        Sorry for the late respond and thanks for your help.
        The only working solution i have found is
        {"jsonrpc":"2.0",
        	"params":{
        		"filter":{
        			"hostid":"10111"
        	"auth":...
        Has anybody futher information why the other way return always all groups as respond. Is the mistake in the api dacumentation or in my way of generatiing the json request?
        • Heilig
          • Mar 2013
          • 366
          The second.
          • Pavels
            • Oct 2011
            • 83
            The easiest way to do it would be to use the hostgroup.get method with the hostids parameter:
                "jsonrpc": "2.0",
                "method": "hostgroup.get",
                "params": {
                    "output": "extend",
                    "hostids": "10111"
                "id": 3,
                "auth": "0a64b1dbefe61264d88a3d5bee3b8ae2"
            Refer to the API documentation for additional information
