Hi everyone,
I am trying to industrialize the configuration of Zabbix for Cisco clusters.
I am working with Cisco ASA firewalls configured in cluster.
I want to be able to generate graphs that use items from both cluster members like this one :
It works fine manually but I would really like it to be inserted in the Cisco ASA template.
The problem I am facing is that all items of the template are copied in the host associated to that template without restriction.
I would like to be able to say which items shoud be copied to one host and which should be copied to the other host using maybe some kind of key to make the distinction.
I have also tried to make 3 templates :
- the 1st for the master firewall using item keys primary (to differentiate from the secondary template item key)
- the 2nd for the backup firewall using item keys secondary
- the 3rd for the cluster
I wanted to import the cluster template to the other 2 templates so I could create a graph in the cluster template that would use items from template master and template backup. That did not work because I could not access any of the items of these templates from template cluster.
Does anyone know how to realize this using one of these ideas or even another one I haven't thought about ?
Any help will be very much appreciated
Lily
Lily
