HI there!
Please give or point me to any source of information regarding the analysis of log files using Zabbix 1.1. I've set up the analysis of /var/log/syslog using the documentation. That worked quite well.
Now, I'd like to set the parameters for the "severity"-column. How do I do this? I've set up a trigger using
{localhost:log[/var/log/syslog].str(test)}=1
and set the trigger-severity to "warning". So it should trigger a warning, when the string "test" comes up in the log.
But this doesn't happen. And the severity-column in the log file analysis page shows "undefined".
Is there any kind of documentation about this feature?
Kind regards,
Dennis
Kind regards,
Dennis
