Help on cleaning up the database
  • burn1024
    • Jun 2012
    • 52
    Our database seems to be growing too quick, and so we decided to have some serious cleanup:
    1) disable most triggers that come by default (/vmlinuz size, "Configured max number of opened files", etc)
    2) set larger update intervals for all items
    3) disable all items that are not used in any triggers
    4) clear history and trends for all disabled items
    The question is - how do I perform 3) and 4) without spending 2 days in Zabbix WebUI?
    We're using Zabbix 1.8.1 with Postgresql 8.4.17.
  • burn1024
    • Jun 2012
    • 52
    Just for the record:
    1-3) Done manually, it turned out to be quick.
    4)
    delete FROM alerts where age(to_timestamp(alerts.clock)) > interval '7 days';
    delete FROM acknowledges where age(to_timestamp(acknowledges.clock)) > interval '7 days';
    delete FROM events where age(to_timestamp(events.clock)) > interval '7 days';
    delete FROM history where age(to_timestamp(history.clock)) > interval '7 days';
    delete FROM history_uint where age(to_timestamp(history_uint.clock)) > interval '7 days' ;
    delete FROM history_str  where age(to_timestamp(history_str.clock)) > interval '7 days' ;
    delete FROM history_text where age(to_timestamp(history_text.clock)) > interval '7 days' ;
    delete FROM history_log where age(to_timestamp(history_log.clock)) > interval '7 days' ;
    delete FROM trends where age(to_timestamp(trends.clock)) > interval '90 days';
    delete FROM trends_uint where age(to_timestamp(trends_uint.clock)) > interval '90 days' ;
    delete from history where itemid not in (select itemid from items where status='0');
    delete from history_uint where itemid not in (select itemid from items where status='0');
    delete from history_str where itemid not in (select itemid from items where status='0');
    delete from history_text where itemid not in (select itemid from items where status='0');
    delete from history_log where itemid not in (select itemid from items where status='0');
    delete from trends where itemid not in (select itemid from items where status='0');
    delete from trends_uint where itemid not in (select itemid from items where status='0');
    and also applied https://github.com/mattiasgeniar/zab...d-data-cleanup
    • barbaros
      • Aug 2010
      • 32
      Originally posted by burn1024
      Does those scripts work for PostgreSQL?
      • burn1024
        • Jun 2012
        • 52
        yes.
        P.S. let the admin who configured "your message is too short" for this forum rot in hell.
        • barbaros
          • Aug 2010
          • 32
          Didn't you have any problems with Zabbix after manual data deleting?
          • burn1024
            • Jun 2012
            • 52
            No, why would I?
            • barbaros
              • Aug 2010
              • 32
              Sometimes manual intervention brokes things . Good to know everything went well, I am going to do the same operation on my DB.
              • barbaros
                • Aug 2010
                • 32
                "select itemid from items where status='0'" means disabled items?
                • burn1024
                  • Jun 2012
                  • 52
                  No it means enabled.
                  • barbaros
                    • Aug 2010
                    • 32
                    Yes, I've meant enabled, sorry . THX.
