Hi Team,
I am quiet new with zabbix.
I followed the instructions from the following site and installed Zabbix server.
Then I installed zabbix proxy on the main site and also zabbix agent.
The server is on 192.168.0.90/24 and the proxy is 192.168.0.200/24 which is also the pfsense firewall.
Now I have a site to site link to a few sites all via pfsense. I installed zabbix agent on all the remote pfsense but can seems to get the zabbix agent connect to the server.
So site A is connected back to the main site via link 10.0.20.0/24 and the route that is pushed through is 192.168.23.0/24 which is from the main site and local lan from the remote site is 192.168.20.0/24.
The setting for the remote agent is as follows:
enable : yes
Server : 192.168.23.200:10051
Hostname: remote
Listen IP : 0.0.0.0
Listen Port : 10050
Refresh Active checks : 120
Timeout : 3
Buffer Send : 5
Buffer Size : 100
Start Agents : 3
Can anyone assist on how I can get the remote zabbix agent to talk to the server via the proxy pls.
I hope I have asked the question at the right place.
Cheers,
Raj
enable : yes
Hostname: remote
Listen IP : 0.0.0.0
Listen Port : 10050
Timeout : 3
Buffer Send : 5
Buffer Size : 100
Start Agents : 3
Cheers,
Raj
