Hello, I have asked this question previously but could not find an answer so am re-phrasing in the hope someone can have another look.
My understanding from the docs is that I should be able to use (host) active checks to report data back to the Zabbix server without the server requiring access to port 10050 on the host. We plan to use this scenario for client hosts out on the internet that will report back to our Zabbix server. In Zabbix 2.06 we cannot get this to work so for a start, it would be great to have confirmation from someone using this method that the above should be working. Any help much appreciated.
Experimenting with active only checks (no access to port 10050 from Zabbix server to host)
Using debian squeeze and the 2.06 debs from the Zabbix docs here ... https://www.zabbix.com/documentation...#debian_ubuntu
I am able to install succesfully and "auto registration" works fine but "active only checks" are not working no matter what I do (no data reported on server GUI)
Installed a clean copy of Squeeze with above zabbix install, both server and host are on the same network with only a dumb soho switch in between.
client is a windows 8 machine but same result on server 2008 and windows 7.
Windows host config
StartAgents=0
ServerActive=192.168.4.202
LogFile=c:\zabbix\zabbix_agentd.log
Linux server config
root@zabbixl:/home/administrator# grep ^[^#] /etc/zabbix/zabbix_server.conf
LogFile=/var/log/zabbix/zabbix_server.log
LogFileSize=0
PidFile=/var/run/zabbix/zabbix_server.pid
DBHost=localhost
DBName=zabbix
DBUser=zabbix
DBPassword=xxx
DBSocket=/var/run/mysqld/mysqld.sock
AlertScriptsPath=/usr/lib/zabbix/alertscripts
ExternalScripts=/usr/lib/zabbix/externalscripts
FpingLocation=/usr/bin/fping
Fping6Location=/usr/bin/fping6
==snip of host log==
476:20130617:144650.698 Starting Zabbix Agent [TESTER-PC]. Zabbix 2.0.6 (revision 35155).
476:20130617:144650.699 In init_collector_data()
476:20130617:144650.701 End of init_collector_data()
476:20130617:144650.702 In init_perf_collector()
476:20130617:144650.704 End of init_perf_collector():SUCCEED
8816:20130617:144650.705 agent #0 started [collector]
5508:20130617:144650.707 agent #1 started [active checks]
8816:20130617:144650.708 In init_cpu_collector()
5508:20130617:144650.709 In init_active_metrics()
8816:20130617:144650.711 In get_counter_name() pdhIndex:238
5508:20130617:144650.712 Buffer: first allocation for 100 elements
5508:20130617:144650.715 In send_buffer() host:'192.168.4.202' port:10051 values:0/100
5508:20130617:144650.717 End of send_buffer():SUCCEED
5508:20130617:144650.719 refresh_active_checks('192.168.4.202',10051)
5508:20130617:144650.723 sending [{
"request":"active checks",
"host":"TESTER-PC"}]
5508:20130617:144650.725 before read
5508:20130617:144650.729 got [{
"response":"success",
"data":[]}]
5508:20130617:144650.731 In parse_list_of_checks()
5508:20130617:144650.733 In disable_all_metrics()
5508:20130617:144650.735 In process_active_checks('192.168.4.202',10051)
5508:20130617:144650.737 End of process_active_checks()
5508:20130617:144650.739 In get_min_nextcheck()
5508:20130617:144650.740 Sleeping for 1 second(s)
8816:20130617:144650.797 End of get_counter_name():SUCCEED
8816:20130617:144650.799 In get_counter_name() pdhIndex:6
8816:20130617:144650.800 End of get_counter_name():SUCCEED
8816:20130617:144650.801 In add_perf_counter() counter:'\Processor(_Total)\% Processor Time' interval:900
8816:20130617:144650.803 add_perf_counter(): PerfCounter '\Processor(_Total)\% Processor Time' successfully added
8816:20130617:144650.805 In add_perf_counter() counter:'\Processor(0)\% Processor Time' interval:900
8816:20130617:144650.806 add_perf_counter(): PerfCounter '\Processor(0)\% Processor Time' successfully added
8816:20130617:144650.807 In add_perf_counter() counter:'\Processor(1)\% Processor Time' interval:900
8816:20130617:144650.808 add_perf_counter(): PerfCounter '\Processor(1)\% Processor Time' successfully added
8816:20130617:144650.810 In add_perf_counter() counter:'\Processor(2)\% Processor Time' interval:900
8816:20130617:144650.811 add_perf_counter(): PerfCounter '\Processor(2)\% Processor Time' successfully added
8816:20130617:144650.813 In add_perf_counter() counter:'\Processor(3)\% Processor Time' interval:900
8816:20130617:144650.814 add_perf_counter(): PerfCounter '\Processor(3)\% Processor Time' successfully added
8816:20130617:144650.816 In get_counter_name() pdhIndex:2
8816:20130617:144650.817 End of get_counter_name():SUCCEED
8816:20130617:144650.818 In get_counter_name() pdhIndex:44
8816:20130617:144650.820 End of get_counter_name():SUCCEED
8816:20130617:144650.821 In add_perf_counter() counter:'\System\Processor Queue Length' interval:900
8816:20130617:144650.823 add_perf_counter(): PerfCounter '\System\Processor Queue Length' successfully added
8816:20130617:144650.825 End of init_cpu_collector():SUCCEED
8816:20130617:144650.826 In collect_perfstat()
8816:20130617:144650.828 collect_perfstat() '\System\Processor Queue Length' calculated value:0.000000
8816:20130617:144650.830 End of collect_perfstat()
5508:20130617:144651.742 In send_buffer() host:'192.168.4.202' port:10051 values:0/100
5508:20130617:144651.750 End of send_buffer():SUCCEED
5508:20130617:144651.803 Sleeping for 1 second(s)
8816:20130617:144651.833 In collect_perfstat()
8816:20130617:144651.841 collect_perfstat() counterpath:'\System\Processor Queue Length' old first:0 second:0
8816:20130617:144651.847 collect_perfstat() counterpath:'\System\Processor Queue Length' new first:0 second:0
8816:20130617:144651.853 collect_perfstat() '\System\Processor Queue Length' calculated value:0.000000
8816:20130617:144651.860 collect_perfstat() counterpath:'\Processor(3)\% Processor Time' old first:831868281250 second:130159180108288976
8816:20130617:144651.866 collect_perfstat() counterpath:'\Processor(3)\% Processor Time' new first:831877812500 second:130159180118390912
8816:20130617:144651.872 collect_perfstat() '\Processor(3)\% Processor Time' calculated value:5.649274
8816:20130617:144651.878 collect_perfstat() counterpath:'\Processor(2)\% Processor Time' old first:822216562500 second:130159180108288976
8816:20130617:144651.882 collect_perfstat() counterpath:'\Processor(2)\% Processor Time' new first:822225937500 second:130159180118390912
8816:20130617:144651.886 collect_perfstat() '\Processor(2)\% Processor Time' calculated value:7.196007
8816:20130617:144651.889 collect_perfstat() counterpath:'\Processor(1)\% Processor Time' old first:828320000000 second:130159180108288976
8816:20130617:144651.893 collect_perfstat() counterpath:'\Processor(1)\% Processor Time' new first:828330000000 second:130159180118390912
8816:20130617:144651.896 collect_perfstat() '\Processor(1)\% Processor Time' calculated value:1.009074
8816:20130617:144651.900 collect_perfstat() counterpath:'\Processor(0)\% Processor Time' old first:808615781250 second:130159180108288976
8816:20130617:144651.904 collect_perfstat() counterpath:'\Processor(0)\% Processor Time' new first:808625625000 second:130159180118390912
8816:20130617:144651.907 collect_perfstat() '\Processor(0)\% Processor Time' calculated value:2.555807
8816:20130617:144651.910 collect_perfstat() counterpath:'\Processor(_Total)\% Processor Time' old first:822755156250 second:130159180108288976
8816:20130617:144651.913 collect_perfstat() counterpath:'\Processor(_Total)\% Processor Time' new first:822764843750 second:130159180118390912
8816:20130617:144651.915 collect_perfstat() '\Processor(_Total)\% Processor Time' calculated value:4.102540
8816:20130617:144651.917 End of collect_perfstat()
5508:20130617:144652.811 In send_buffer() host:'192.168.4.202' port:10051 values:0/100
5508:20130617:144652.818 End of send_buffer():SUCCEED
--Server log snip --
5349:20130617:144707.553 Trapper got [{
"host":"TESTER-PC"}] len 50
5349:20130617:144707.553 In send_list_of_active_checks_json()
5349:20130617:144707.553 In get_hostid_by_host() host:'TESTER-PC'
5349:20130617:144707.553 query [txnlev:0] [select hostid,status from hosts where host='TESTER-PC' and status in (0,1) and proxy_hostid is null and hostid between 0 and 99999999999999]
5349:20130617:144707.554 End of get_hostid_by_host():SUCCEED
5349:20130617:144707.554 query [txnlev:0] [select i.key_,i.delay,i.lastlogsize,i.mtime from items i,hosts h where i.hostid=h.hostid and h.status=0 and i.type=7 and i.flags<>2 and h.hostid=10085 and h.proxy_hostid is null]
5349:20130617:144707.555 send_list_of_active_checks_json() sending [{
"data":[]}]
5349:20130617:144707.555 End of send_list_of_active_checks_json():SUCCEED
5342:20130617:144708.213 In get_values()
5342:20130617:144708.213 In DCconfig_get_poller_items() poller_type:0
5342:20130617:144708.213 End of DCconfig_get_poller_items():0
5342:20130617:144708.213 End of get_values():0
5342:20130617:144708.213 poller #4 spent 0.000269 seconds while updating 0 values
5342:20130617:144708.213 In DCconfig_get_poller_nextcheck() poller_type:0
5342:20130617:144708.213 End of DCconfig_get_poller_nextcheck():1371444431
5342:20130617:144708.213 sleeping for 3 seconds
5340:20130617:144708.215 In get_values()
5340:20130617:144708.215 In DCconfig_get_poller_items() poller_type:0
5340:20130617:144708.215 End of DCconfig_get_poller_items():0
5340:20130617:144708.215 End of get_values():0
5340:20130617:144708.215 poller #2 spent 0.000155 seconds while updating 0 values
5340:20130617:144708.215 In DCconfig_get_poller_nextcheck() poller_type:0
5340:20130617:144708.215 End of DCconfig_get_poller_nextcheck():1371444431
5340:20130617:144708.215 sleeping for 3 seconds
5350:20130617:144708.215 In get_pinger_hosts()
5350:20130617:144708.216 In DCconfig_get_poller_items() poller_type:3
5350:20130617:144708.216 End of DCconfig_get_poller_items():0
5350:20130617:144708.216 End of get_pinger_hosts():0
5350:20130617:144708.216 In process_pinger_hosts()
5350:20130617:144708.216 End of process_pinger_hosts()
5350:20130617:144708.216 icmp pinger #1 spent 0.000225 seconds while processing 0 items
5350:20130617:144708.216 In DCconfig_get_poller_nextcheck() poller_type:3
5350:20130617:144708.216 End of DCconfig_get_poller_nextcheck():-1
5350:20130617:144708.216 sleeping for 5 seconds
Windows host config
StartAgents=0
Linux server config
LogFileSize=0
DBHost=localhost
DBName=zabbix
DBUser=zabbix
DBPassword=xxx
"data":[]}]
"data":[]}]
