PostgreSQL - low level disvoery
  • ufocek
    • Aug 2006
    • 161
    I have db server where catalog pg_xlog is locate on separate partition and zabbix doesn't has permission to read. If I set any different permissions than 0700 to /var/lib/postgresql/9.2/main, postgresql doesn't start, because the permission should be 0700...
    Any sugestions how to fix this problem?
