multi-server mode?
  • sobdog
    • Jun 2006
    multi-server mode?
    can i run Zabbix in Multiserver-Mode?
    I want to use 4 Servers on different locations for reliability.
    Thanks for help.
    Greets Timo
  • erisan500
    • Aug 2005
    • 285
    Search the forum, has been implemented and discussed before
    Greetings
    EriSan
    • sobdog
      • Jun 2006
      Sorry i searched the forum. But I don't find anythink. Can you give me a hint for some search words? Thanks
      • SLMitch
        • May 2006
        • 39
        I would like to use several server to
        On the forum, i found a patch for zabbix-1.1beta1, which is too old to be used at all with recent sources.
        I read the source, and i note only the part of conf is patched (Server = XX), but there aren't any other modification on source (serverid, etc ..).
        This projet is dead ?
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          The project is not dead. It is very likey that this functionality will be part of ZABBIX roadmap of the next release.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
