Monitor number of files in folder
  • dominic
    • Sep 2005
    i will monitor the files in a folder.
    If more the 5 files longer then 10 minutes exists Zabbix should send an e-mail.
    I have created a external command that gives me the number of files in a folder.
    ls /Temp/ | wc -l
    But what trigger I have to use?
    I have tried:
    {Zabbix:ssh.run[TestSUN,172.16.48.20,22,].last(600)}>1
    {Zabbix:ssh.run[TestSUN,172.16.48.20,22,].nodata(600)}>1
    It will not work. I always get directly an e-mail if a file in the folder exists.
    Can someone help me with the trigger?
    Regards
    Dominic
  • dmartel
    • Jun 2013
    What I did at my work, I've created a Perl script that analyses the content of an XML file and at the end, writes the data into a file and sends data to Zabbix through zabbix_sender.
    I'm sure you could do your own script, executed at an interval (by cron task) to fit your needs!
    David
    • dominic
      • Sep 2005
      Hallo,
      is there no way to monitor a value for a given time without an external script like Perl?
      If the value for example is 1 for 5 minutes then send a e-mail?
      I think that should be a basic function of Zabbix.
      Is there a way to get it in the next release of Zabbix?
      Regards
      Dominic
