best practice for trigger severity defined in template?
  • harri
    • Nov 2010
    • 89
    Hi folks,
    What would you consider as best practice to manage the trigger severities in a template?
    Usually the set of triggers is pretty much the same for a set of similar servers, but the severity is not (e.g. looking at staging and production servers). I would like to avoid to manage 2 or more templates just with different severities.
    Every helpful comment is highly appreciated
    Harri
  • tchjts1
    • May 2008
    • 1605
    If you don't want to manage multiple templates, I think your only other option is to manually change the trigger severity at the host level.
