I have a python script to find out get all hosts managed under Zabbix.
method = 'host.get'
params = { "output" : "extend", }
params['search'] = { "host" : '*' }
params['searchWildcardsEnabled'] = 1
params['limit'] = 5000
error, response = request(method, params)
pprint.pprint(len(response['result'][0]))
Everything else works with the API but when I try to search all, I see zabbix returns 31 hosts and failed to connect again. Any suggestions or an easier way to get all hosts managed by Zabbix? Thank you.
31
{u'available': u'2',
u'disable_until': u'1372082270',
u'error': u'Get value from agent failed: cannot connect to [[zabbix.local]:10050]: [111] Connection refused',
u'errors_from': u'1372075070',
u'host': u'zabbix.local',
u'hostid': u'100100000010084',
u'ipmi_authtype': u'-1',
u'ipmi_available': u'0',
u'ipmi_disable_until': u'0',
u'ipmi_error': u'',
u'ipmi_errors_from': u'0',
u'ipmi_password': u'',
u'ipmi_privilege': u'2',
u'ipmi_username': u'',
u'jmx_available': u'0',
u'jmx_disable_until': u'0',
u'jmx_error': u'',
u'jmx_errors_from': u'0',
u'lastaccess': u'0',
u'maintenance_from': u'0',
u'maintenance_status': u'0',
u'maintenance_type': u'0',
u'maintenanceid': u'0',
u'maintenances': [],
u'name': u'zabbix.local',
u'proxy_hostid': u'0',
u'snmp_available': u'0',
u'snmp_disable_until': u'0',
u'snmp_error': u'',
u'snmp_errors_from': u'0',
u'status': u'0'}
method = 'host.get'
31
u'ipmi_error': u'',
u'jmx_error': u'',
u'snmp_error': u'',
u'status': u'0'}
