Filesystem discovery - exclude a mount point
  • mvrk
    • Oct 2008
    • 71
    I don't understand much about regular expressions, but is there anyway for example to modify the regular expression used on the filesystem discovery so that it could exclude for example /mnt/outbackup?
  • neogan
    • Sep 2011
    • 118
    What is filesystem uses on the "/mnt/outbackup"?
    Could you show output of "df -h" command?
    • mvrk
      • Oct 2008
      • 71
      Filesystem Size Used Avail Use% Mounted on
      /dev/mapper/vg0-lv.root
      9,8G 5,9G 3,5G 63% /
      /dev/mapper/vg0-lv.home
      1,8G 481M 1,2G 29% /home
      /dev/mapper/vg0-lv.log
      960M 67M 843M 8% /var/log
      /dev/sda2 99M 41M 54M 44% /boot
      tmpfs 1,5G 0 1,5G 0% /dev/shm
      /dev/mapper/vg_share-lv.share
      54G 49G 2,5G 96% /mnt/share
      /dev/mapper/vg_backups-lv.backups
      916G 791G 79G 91% /mnt/backups
      /dev/sdf1 917G 766G 105G 88% /mnt/outbackup
