zabcon still working with Zabbix 2.0
  • thensel
    • Jun 2012
    Hi all,
    I use zabbix 2.0.0
    I tried to use zabcon. I installed as described on http://trac.red-tux.net/wiki
    It installed Version Build Number: 392
    When I try to login I get an invalid username or password
    root@mon-vm:~# /var/lib/gems/1.8/bin/zabcon.rb
    x86_64-linux
    Failed to load previous session key
    Found valid login credentials, attempting login
    WARNING: Initialization has changed, backwards compatability is being used.
    WARNING: Use ZabbixAPI.new(url,:debug=>n,:returntype=>:result) to have the
    WARNING: same capability as previous versions.
    WARNING: This depreciated functionality will be removed in a future release
    Invalid User or Password
    Welcome to Zabcon.  Build Number: 392
    Use the command 'help' to get help on commands
    The username and the password are correct.
    So maybe zabcon does not work with zabbix 2?
