Zabbix Proxy on Raspberry Pi
  • brhunt
    • Feb 2013
    • 50
    Can anyone point me to a guide for setting up a Raspberry Pi unit as a Zabbix Proxy?
    I have seen several posts about people planning to implement this, but have been unable to find a step-by-step guide on how to accomplish this.
    Bryan Hunt
  • mattc
    • Jun 2013
    • 11
    Just follow the standard "compile from source" instructions for Debian on the wiki for the 2.06 version.
    I did this a few days ago and it works well and doesnt take long to compile (proxy and agent)
    I started off with the raspbarian wheezy image.
    cheers
    -Matt
    • alledm
      • May 2012
      • 84
      the best thing is to use a "raspberry simulator" to compile it otherwise it will take ages to compile
      qemu-system-arm -kernel kernel-qemu -cpu arm1176 -m 256 -M versatilepb -no-reboot -serial stdio -append "root=/dev/sda2 panic=1" -hda Downloads/2013-02-09-wheezy-raspbian.img
      Get the latest kernel from
      http://www.raspberrypi.org/phpBB3/viewtopic.php?t=16081
      you can also increase the memory to 1024 because sometimes the compiler will crash if it does not have enough memory.
      Regards
