Hi all,
I've created a child with a nodeID of 268 and the Master with nodeID of 999. I can see the latest data from the child and the events from the child, but when I go to Monitoring>Maps and select the child node from the Current Node dropdown, I get "No maps defined". My question is this, are the maps from the child duplicated to the master? When I setup a test before doing this in production, I seem to recall that this was the case, could someone please confirm? Or how can I trigger a sync from the child?
Zabbix server v2.0.5 (revision 33558) (12 February 2013)
Compilation time: Feb 19 2013 11:30:16
I think it has to do with this on the master
2013-07-02 13:27:37 SAST ERROR: insert or update on table "sysmaps_elements" violates foreign key constraint "c_sysmaps_elements_1"
2013-07-02 13:27:37 SAST DETAIL: Key (sysmapid)=(11111100000000001) is not present in table "sysmaps".
2013-07-02 13:27:37 SAST STATEMENT: insert into sysmaps_elements (selementid,sysmapid,elementid,elementtype,iconid_ off,iconid_on,label,label_location,x,y,iconid_disa bled,iconid_maintenance,elementsubtype,areatype,wi dth,height,viewtype,use_iconmap) values (11111100000000003,11111100000000001,1111110000001 0084,0,11111100000000024,NULL,'and another',0,293,67,NULL,NULL,0,0,200,200,0,0);
Thanks!!!
12397:20130702:121117.560 NODE 268: Received configuration changes from master node 999 for node 268 datalen 12
12397:20130702:121117.719 NODE 268: Sending history_sync of node 268 to node 999 datalen 4314
12397:20130702:121117.926 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 4029
12397:20130702:121121.311 NODE 268: Sending history_log of node 268 to node 999 datalen 14618
12397:20130702:121121.901 NODE 268: Sending events of node 268 to node 999 datalen 778
12397:20130702:121122.854 NODE 268: Sending history_sync of node 268 to node 999 datalen 2274
12397:20130702:121123.035 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 664
12397:20130702:121132.214 NODE 268: Sending history_sync of node 268 to node 999 datalen 915
12397:20130702:121132.372 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 805
12397:20130702:121142.591 NODE 268: Sending history_sync of node 268 to node 999 datalen 867
12397:20130702:121142.741 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 530
12397:20130702:121152.970 NODE 268: Sending history_sync of node 268 to node 999 datalen 733
12397:20130702:121153.125 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 882
12397:20130702:121202.333 NODE 268: Sending history_sync of node 268 to node 999 datalen 726
12397:20130702:121202.494 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 132
12397:20130702:121212.690 NODE 268: Sending history_sync of node 268 to node 999 datalen 581
12397:20130702:121212.845 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 1168
12397:20130702:121222.971 NODE 268: Sending history_sync of node 268 to node 999 datalen 1742
12397:20130702:121223.142 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 1218
12397:20130702:121223.453 NODE 268: Sending history_log of node 268 to node 999 datalen 690
12397:20130702:121242.026 NODE 268: sending configuration changes to master node 999 for node 268 datalen 171
12397:20130702:121320.235 NODE 268: Received configuration changes from master node 999 for node 268 datalen 12
12397:20130702:121320.381 NODE 268: Sending history_sync of node 268 to node 999 datalen 5715
12397:20130702:121320.637 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 4626
12397:20130702:121321.010 NODE 268: Sending history_log of node 268 to node 999 datalen 3210
12397:20130702:121332.225 NODE 268: Sending history_sync of node 268 to node 999 datalen 915
12397:20130702:121332.388 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 805
12397:20130702:121342.704 NODE 268: Sending history_sync of node 268 to node 999 datalen 867
12397:20130702:121342.859 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 576
12397:20130702:121353.100 NODE 268: Sending history_sync of node 268 to node 999 datalen 2346
12397:20130702:121353.283 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 882
12397:20130702:121353.577 NODE 268: Sending history_log of node 268 to node 999 datalen 18923
12397:20130702:121354.215 NODE 268: Sending events of node 268 to node 999 datalen 2668
12397:20130702:121402.428 NODE 268: Sending history_sync of node 268 to node 999 datalen 726
12397:20130702:121402.580 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 132
12397:20130702:121412.787 NODE 268: Sending history_sync of node 268 to node 999 datalen 581
12397:20130702:121412.935 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 1168
12397:20130702:121422.175 NODE 268: Sending history_sync of node 268 to node 999 datalen 1057
12397:20130702:121422.330 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 1217
12397:20130702:121432.570 NODE 268: Sending history_sync of node 268 to node 999 datalen 915
12397:20130702:121432.726 NODE 268: Sending history_uint_sync of node 268 to node 999 datalen 805
12397:20130702:121452.369 NODE 268: sending configuration changes to master node 999 for node 268 datalen 330
Thanks!!!
