Dear all,
I have a problem getting data from an AIX 5 system. I get only now and then data but not continously, is that problem known?
The items which are affected are: diskfree[] and disktotal[]
Wich command do you procced on AIX side to get this data from it?
THX,
Globes
THX,
Globes
I believe you check disk space once per 30 minutes, so you see straight line between two points.
