Macros in MAPS
  • Frederico
    • Jun 2010
    • 9
    Macros in MAPS
    Not working some macros in maps
    I check in https://www.zabbix.com/documentation...ed_by_location
    and seems correct my settings
    Using zabbix 2.0.6
    On maps, host text,
    This works
    {HOST.NAME}
    {HOST.IP}
    This NOT
    {HOST.NAME}
    {HOST.IP2}
    I missing something ?
  • eskytthe
    • May 2011
    • 363
    As far as I know you can only use the "MACRO<1-9>" notation in trigger names.
    Remark this note in the start of the document:
    "{MACRO<1-9>} syntax allows to reference items in the order, in which they appear in a trigger expression (containing more than one item). For example, {HOST.IP1} and {HOST.IP2} will expand to the IPs of the first and second host in a trigger expression."
    BR
    Erik
    • Frederico
      • Jun 2010
      • 9
      in fact had not understood this way.
      Is there any way to display multiple ips for a host on map?
      • avenn
        • Nov 2011
        • 12
        Macros in MAPS - HOST.IP
        Hi Frederico,
        Any progress with this issue?
        Cheers
        Aidan
