UPDATE ZABBIX from Appliance, DB restoring
  • zabbixx
    • Jul 2012
    • 71
    Hello all.
    we are using a langer VW Invirement and we use zabbix for monitoring this.
    the fastes way for us is to get zabbix whit the Appliance (OpenSuse) and mirate it to our Invirement.
    we have running zabbix 2.0.3 Appliance, now i want to update it to 2.0.6 Appliance
    i have dumpt the DB whit mysqldump (2,5GB file), after restoring the db all looks wel ( zabbix is not working)
    in the Monitoring Dashbord we can see exact the same status of zabbix
    Zabbix server is running Yes localhost:10051
    Number of hosts (monitored/not monitored/templates) 80 45 / 0 / 35
    Number of items (monitored/disabled/not supported) 991 801 / 27 / 163
    Number of triggers (enabled/disabled)[problem/unknown/ok] 410 409 / 1 [14 / 0 / 395]
    Number of users (online) 11 1
    Required server performance, new values per second 21.03 -
    but after we start the zabbix server binary there are less triggers?
    Number of items (monitored/disabled/not supported) 991 473 / 27 / 491
    Number of triggers (enabled/disabled)[problem/unknown/ok] 52 51 / 1 [0 / 0 / 51]
    Required server performance, new values per second 14.33 -
    I dont now why zabbix is dropping the triggers after start.
    any ideas?
    thx zabbixx
  • zabbixx
    • Jul 2012
    • 71
    I found the reason, the extern scripts was not executable....
    so many iteams (Template) are not supported :-(
