Possible to access zabbix-agent directly
  • vic
    • Jul 2013
    • 58
    I want to set up something on a website that allows people to ping from their PC to my servers. Perhaps with a graph plot over time kind of like what pingplotter pro does only this will be on my website.
    Initiating ICMP is not really possible via a website from what I have read. Since I already have zabbix-agent on my servers I was wondering if I could perhaps use it for this. It would have to be accessed directly with PHP+Java. Not via zabbix-server since server is not designed for this.
  • steveboyson
    • Jul 2013
    • 582
    You cannot start actions on a user's system. Why not measure something different, e.g. the time to load a specific image from your server?
    http://stackoverflow.com/questions/4...ing-javascript
    • vic
      • Jul 2013
      • 58
      Originally posted by steveboyson
      You cannot start actions on a user's system. Why not measure something different, e.g. the tome to load a specific image from your server?
      Sure about that?
      • steveboyson
        • Jul 2013
        • 582
        I understood your posting in that way that you want to start a ping from the client machine via a website.
        Installing a Zabbix agent does not fall into that type of "starting a ping".
        BTW, how would you initiate a remote command from the Zabbix frontend ON DEMAND (e.g. by "click")?
        Alas, pinging from your servers to your people's PC ist different from doing it the opposite direction.
